Hello,
I’m looking to install an inground vinyl liner pool kit from Pool Warehouse this spring and wanted opinion from this forum prior to making any final decisions. Here are my current specs:
16ft x 32ft rectangle
42” steel walls, coved bottom with 5ft height (4ft-6” water depth)
Tanning ledge with steps on one end
(2) skimmers
(1) set of main drains
(3) returns
Pump: 2.2HP Aqua Genie Variable Speed (2” inlet)
Filter: 31” Aqua Genie Top Mount Sand Filter
In-line Auto Chlorinator
Heater: Hayward 275k BTU Natural Gas
Single Light (500 Watt) on opposite end from tanning ledge, may move to middle of the one of the long sides.
I plan on running all schedule 40 PVC for the plumbing and using Jandy Valves
The main drains are required here per code as well as tying them back into the sanitary sewer line of the house.
Questions:
(2) skimmers
(3) returns
Questions:
- Does my equipment look to be sized appropriately (# of skimmer/returns/pump size/filter/heater/etc.)?
- What is the recommended way to plumb the main drains and skimmers back at the equipment pad? (see the below plumbing detail for how I currently have it drawn with 3-way valves separating the 2 skimmers and then another 3-way valve separating the main drains). Are there benefits for this, or should I just have 2 ways valves for each line connected to a common header before going into the pump for the skimmers and main drains?
- What is the recommended way to plumb the return lines at the equipment pad? Should I have separate piping for each return or daisy chain them as currently shown.
- Recommendations on skimmer locations. The prevailing winds in my area during the summer months are from the South or West and the 2 skimmers are located on the north side of the pool.
- Recommendations on winter covers?
