Bob,
I have three saltwater pools here in the DFW area and always joke that I would just as soon fill them in, if they were not saltwater...
When you get out of a standard chlorine pool you feel like you need to take a shower. When you get out of a saltwater pool, you feel like you just took a shower...
UV and Ozone are just more things that can go wrong and since you have no real way to test them, you just have to trust that they are working like you want. Just to be clear UV and Ozone are not sanitizers, you still have to have chlorine in the water.
Just to make sure you understand.. Saltwater pools are chlorine pool, they just make their own chlorine from the slightly salty water using what is called a Saltwater Chlorine Generator or SWCG.. The salt level is about 3,500 ppm. the same as your tears, it is not like the ocean which is 35,000 ppm.
Saltwater pools do not smell, like public pools that you might remember as a kid.
Since you appear to have Pentair equipment, you will need an IntelliChlor IC60.. Since you have a spa, I have to assume that you will have a Pentair automation system. If so, you should get the automation package that includes an internal power center and an IC60 SWCG.
Cells typically last 5 to 7 years before they run out of the ability to make chlorine.
If I built a 100 more pools that would always be saltwater pool.
DFW is a big place, in general, where do live?
Make sure your IntelliFlo does NOT have the SVRS option.. The IntelliFlo is the gold standard of pool pumps, but the SVRS version is more brown, if you catch my drift...
The CCP-520 is a great filter.
