I have a new-to-me hot tub that is FINALLY in place and I'm dying to get into it but it seems that I can't get the water right and I am not sure what to do.
I own a 2000 Arctic Spa Cub model. It holds 1135 litres of water. We just filled it last night with the hose filter and then when it came up to temp this morning I added one capful of Arctic Pure Boost stabilized chlorinating granules as directed by the sheet I got from Arctic Spa. After a couple of hours I used the hth 6 way test strips and it looks like I must have put in too much chlorine because it's off the charts high, looks like 10.
Alkalinity looks like it's around 220 and pH looks like around 9, and TH at 450. My area is known for hard water so they said to add 2 capfuls of pH reducer, wait 2 hours, then another 2 capfuls. I've now added a total of 8 capfuls and continued to tell my hot tub to cycle so it circulates the chemicals and the numbers aren't even budging. On such a small tub shouldn't I be seeing some kind of change at this point?
We were hoping to use the tub tonight. I am guessing this isn't going to happen.
What should I do at this point?
Thanks for any suggestions!
