- Feb 25, 2008
- 162
- Plaster
- Pentair Intellichlor IC-60
My pool started looking cloudy over the last day or so and I discovered to my horror—no Chlorine. Good news is no Combined Chlorine (phew!)
I went back to check the saltwater chlorinator. The cell looks great. It’s practically brand new. The controller for the chlorinator however….is dead. The wall it is attached to has a sooty black pattern. It appears the circuit board blew. It was pretty old in the tooth. It had probably been installed in 2004 or 2005. It is a Zodiac Clearwater LM2-40. It is no longer being made.
I need this replaced. I’ll limp along with liquid chlorine in the meantime. The problem is that I balanced the salt for the LM2-40, which required a minimum of 4000 ppm. My salt is at about 4100 ppm at the moment. I don’t want to do another drain and refill this summer, so I need a system which has a max salt level above 4100 ppm.
I've read about Compupool a bit, but I will still have to do some plumbing to replace I think. Are there any direct replacements for the Zodiac system that don't require replumbing? Or maybe I should bite the bullet and let buy something compatible with my Aqualink controller.
Any thoughts?
Any thoughts?
