Back again (moved away from my parents so pool maintenance went away). Info in my profile by 16000G vinyl pool. Elderly mom didn’t have it covered nor winterized just turned pump on.
She decided a week ago to turn the pump on to clean the pollen/debris off the top which of course stirred up the leaves/debris on the bottom (she did remove some she said).
Have to hunt down my TF100 kit and check regeant age today when I make it back over.
Have basically just backwashed filter/rinsed/ quick backwash daily and scrubbed sides/shallow end.
No way to see the bottom but last time I saw it plenty of leaves etc.
Debating if I want to vacuum it blind or drain 2/3 or so and refill (have landscape irrigation taps so quick to drain and fill) or both vs starting SLAM now with the organics in it.
