Hello all. I have an above ground INTEX 26363EH Ultra XTR 24ft x 12ft with a Krystal Clear Sand Filter pump 26645EG. I've googled and sifted through a lot of these forums but after an overwhelming amount of info and/or some outdated stuff - I figured it'd be better to ask directly.
Super dirty. Somewhat large debris. I've tried a hose-powered vacuum into a mesh bag and it kind of works but would probably take me about a year. I have a little robot vacuum which is great for maintenance but it fills up in literally 10-15 seconds. I've tried a variety of different things and while I am open to advice (if I knew what I was doing... I wouldn't be asking for help lol) I've done a lot of the basics.
My latest attempt I bought a 40ft hose and a vacuum - but then discovered that the pump doesn't have suction such as in that 2015 thread and later discovered that's really by design and largely relies on water pressure to feed it and/or won't work if there's any air/lose prime. I've tried a method I found on Youtube that accomplished it without a pump just using a siphon but I cannot get mine going that route either.
I don't want to get a shop-vac that I have to constantly empty. Even a cheap "commercial" pool vacuum that doesn't need to be emptied as often and can discharge water to an outlet is very expensive.
Anyone have ideas that are affordable that can accomplish what I thought the sand pump could do? debris/water -> intake hose -> pump to waste (no filter) -> discharge hose -> drain
