Our pool came with this heat pump, the Hayward HeatPro HP31005T. There are only 3 buttons on it: power, "-" and "+". It says "OFF" normally, and when you press the power button, it's supposed to say "ON." Then you use the other buttons to raise the temp up and down. But ours just sits there on "OFF." When you press the power button, it beeps after about half a second, and then stays on "OFF." When you press the "-" or "+" buttons, it shows the temperature and raises it up or down, then it flashes a couple of times and goes back to "OFF" and just sits there. There's plenty of water flow, so it's not that.
I called Hayward and after sitting on hold for 30 minutes, I gave up. Messages to our pool tech and the pool dealer have thus far been unanswered.
Anybody? Am I missing something?
