- Jun 18, 2012
- 55
- Plaster
- Jandy Aquapure 1400
Hello everyone. I am getting an LO error on my Hayward H400 heater and need some help troubleshooting. Here is the history on it:
Installed less than a year ago and has worked flawlessly in that time. 3 weeks ago a critter climbed into the heater and my dog went berzerk trying to get to whatever the critter was. She destroyed the power cord to the SWG and the flow switch that goes to the Aqualink. In addition, there were two wires that came off of a brass plug on the outlet of the Hayward heat exchanger that she destroyed, but I do not see where these go, and my Hayward owner's manual is not clear. It shows one side going back into the side of the heat exchanger and the other side not connected to anything.
I replaced the flow switch and power cord for the SWG, but can't get the heater to come on. When I turn it on, the blower comes on and then 2 minutes later shuts off and I get a "LO" error.
My gut feeling is that the problem is the brass plug is some kind of a flow switch but in the owners manual I don't see it referred to at all. In addition, I am using an Aqualink panel to control the heater so I assumed that the Jandy flow switch was controlling that but am not sure. Can anyone help me on this? If in fact this brass plug with wires is necessary, where do the two leads that come off it go? I do not see a place for it in the front of the heater. Will I need to take the top of the unit off? (Which I believe requires the removal of the sides? Any help is appreciated.
TIA
TIA
