Need help with ground leveling
Jun 25, 2014
2
Cabot/Ar
Okay, so we leveled out a 20x20 ft square to install a 18ft round pool. I had researched quite a bit and watched videos on it and tried to advise my boyfriend as much as possible but he wanted to do things the easiest way possible. I was told we would need 2 or 3 yards of sand for the pool to sit on. We ended up using a sod cutter to get all the grass up then we framed it with some wood planks and got 2 yards of sand. Leveled the sand and set up the pool. We also set the legs up on pavers for a more stable base. However, this method of sand and pavers failed me. We ended up getting a large hole in the pool and the water gushing out made the sand wash away, and pavers sink. As of yesterday we drained the pool, and took it down. Looking to getting another pool. But I want to make sure we don't fail on the ground prep this time. So if anyone has any helpful suggestions or ideas on what I should do I would greatly appreciate it.
I've included 3 pictures. 1st pic is of the ground leveled with sand. (used laser level) 2nd pic is of the pool up without pavers 3 pic is of pool filled and pavers under legs. if you look close you can see on the back side where the sand shifted and the legs are a little bit lower in one spot. its the leg that you can see between the top railing of the ladder.
Welcome to TFP. :wave:
So you used a laser level to level the sand? Well, now you have to remove all that sand and use the laser level to level the ground. You must find the lowest spot and start there by removing all the dirt. As you have found, you can not add sand to do the job of virgin ground. Once you dig out the level pad for the pool, you should recess the paver pads so they do not puncture the liner and cause a major leak. Add a layer of sand, smooth it out and put the pool legs on the pads and fill with water.
I used a very similar method to yours WATERBABYBLISS, but I used a transit level to get the ground level before adding sand. I made sure the entire area of bare ground was level with no more than 1/4"-1/8" height difference anywhere in the area. Then I put weed block cloth down and sand on top of that. Compacted the sand, then measured again to make sure everything was level. Started setting up the pool and placed bricks under each leg, making sure the bricks were resting on the ground and not sand.
I tried to tell him that but he wouldn't listen to me. he said it should be fine. lol
it was a used pool. it had a couple of pin holes that I patched up. but this hole in particular was not known about at first until someone stepped on the hole then it just ripped to about 4 inches. We patched it up. then the next day it got stepped on again and ripped another 5 inches. we patched it up again but we just didn't trust that it wouldn't continue to hold much longer.
we did use the laser level on the ground too. I forgot to mention that.
Others have put a tarp over the sand base so that it cannot wash away... how did the pool rip out of curiosity?
The pavers should be flush with the ground.
Just to clarify this.... the pavers should be flush with your sand. In other words, the bottom of your pool and the bottom of your legs need to be at the same height. If you use sand, be sure and "rain" it in before setting up your pool. You can use a sprinkler or a hose to simulate rainfall to pack the sand before set up. If you use sand to level/smooth the ground underneath, you will definitely need a way to retain the sand so it won't wash away.
The pavers should be flush with the bottom of the pool wherever that ends up.
I used sand to smooth the ground, then put 1/4" foam on top of that. I leveled the pavers so they were generally 1/8" lower than the foam, assuming the weight of the pool would compress the foam somewhat. Others have far more knowledge, but I'd expect anything within 1/2" of the bottom of the pool would be fine.
