I need to change out my timer
from the pump to the breaker and there are a few differences I need to know. Any help would be appreciated. Do I wire them the same?
I'm puzzled... your old unit appears to be controlling a 115 volt pump...
But your new T104 is built with a clock that is driven by 220 volts...
I don't have this timer, so I could be wrong, but I don't believe I am... Check out this chart on this page... https://www.intermatic.com/-/media/inriver/5305-8656.ashx/T100-Specifications-EN
I think you need A T103...
What am I missing???
we had a pump replaced it 115 I believe, we haven't used the new one yet but I'm pretty sure the new one is a 115/220 and the guy who hooked it up said he set it to 220. He changed the breaker and said the timer was broken. So we ordered the T104. Is that wrong.
Well if it "was" 120 and got converted to 220 without replacing the clock motor, that may explain why it no longer works.
This timer can be used for either 120V or 240V.
The T104 clock motor requires an input of 208-240V to operate correctly. For 120V operation you'd be better off with a T101 which is set up for 120V as SPST, or you can replace the 240V clock motor in the T104 with a 120V clock motor (assuming there's a neutral wire for the unbalanced load) but that would be more of a Frankenstein that would confuse the next guy who works on it.
