P
poolguy65
I need some advice on replacing a drive unit. I have a Pentair Intelliflo vs+svrs pump. The keypad drive unit was hit by a golf ball popping off the cover and dislodging the keypad / lcd component. Rain water got inside the keypad unit and the inner board. I dried and cleaned out both components. However, the unit will not turn back on and thereby the pump can't be started. My research here in TFP and the internet leads me to believe the drive unit needs to be replaced. However, it appears to me that Pentair only sells this unit for warranty work and I need to buy a new pump 011017. My unit is out of warranty. I have found a few websites that sell what I believe to be a replacement drive unit but am not sure if they are a correct match. I'm also not sure if I have identified the correct model number. On my pump there is a sticker stating Pentair Intelliflo vs+svrs 354017. On the pump under the drive unit there is a sticker stating 350105 Jun 2015. On the side of the pump is a sticker stating 350105S date 07/29/2015. Sunplay has a drive unit 353251 for $619.95. This appears to be the correct part but I'm not positive. (I have placed a call to Ben Carter too) Any advice is appreciated. Thanks.
