I believe I have a leak at my skimmer. The issue is that I don't see any active leaks, so I assume it's leaking through the screws between the liner and the wall.
So far, I've tried the following:
1st attempt: Installed a new butterfly gasket—still leaked.
2nd attempt: Added pool sealant between the gasket, screws, and skimmer—still leaked.
3rd attempt: Repeated the second attempt and used tape, as you can see in the "middle view," to ensure it wrapped around the edge of the skimmer pool wall—still leaking.
I'm considering two more attempts:
4th attempt: Add thick, waterproof membrane tape, wrapping the edge of the skimmer wall to the liner.
5th attempt: Apply a 1.5 x 1.5 ft liner patch and check for leaks before cutting a new hole. Something like this:
Side note -
The middle view picture is how my pool currently looks. It doesn't drop below this level.
the skimmer itself looks fine. There is nothing wet exterior.
Side note -
