This is an intex 48” pool and I have no idea how to secure the ladder. It wobbles from side to side a bit. Drilling into the frame isn’t something I want to do at all. Thanks!
If its wobbling side to side then the base is unstable.. You could re level those blocks, remove the block and put a bigger stone in, or use tap-con and big fender washer and screw the base down to the paver's
I had a similar problem. Look at the last post in this thread with pictures. I wound up putting a piece of wood in between and used clamps. I painted the wood and clamps so its barely noticeable. A-Frame ladder is 1 inch higher than toprail - Page 2
