Hello , my CYA is 70 because I was floating tabs after I added stabilizer to get pool to 30 . I know now and use liquid chlorine at 12.5 % I know my target levels is 8-10 and no less than 5 for free chlorine now but since I’m running higher chlorine Ppm it’s harder to know where my PH is cause it reads high . I use a Taylor test kit and yesterday my PH was perfect 7.4 and I added chlorine to get FC over 5 . I got home from work today and FC is 6.8 but my ph is showing almost 8 now . Do I drop the PH or is it showing high because my fc levels are high . Thanks for the help .
