Hi
I just received my order of muriatic acid and its labelled as hydrochloric acid. I know they are essentially the same thing, with muriatic having high baume rating due to impurities, but can I safely use hydrochloric in my hot tub to lower ph/ta?
My ta is very high hence why I ordered the liquid acid. Using dry acid is costing a fortune.
This hydrochloric acid is labelled as "Hydrochloric Acid 36". I assume the 36 means 36%. The PoolMath calculator doesn't go up to this strength. Is this safe to use?
Thanks
Lee
Thanks
Lee
