Hi All,
I was wondering if the attached estimate to replace a multiport valve for my sand filter as well as a 2" union check valve was fair. $661.55 for the work. Also not sure how hard this would be to just do myself. I've included a pic of the estimate and my setup. I'm actually not sure where the check valve is here... I think I have the multiport valve and 2 check valves circled? The spa water level goes down when the pump is off which is why a check valve needs replaced.
Also - still looks like my pump is leaking
Thank you!
Thank you!
