- Aug 19, 2018
- 921
- Vinyl
- CircuPool RJ-45
The time has come to replace my ancient ball valves. Waiting on the truck to deliver the new Pentairs (cheaper than Jandy, and locally parts are more available).
The pool was originally done in all 1 1/2" pipe. When I had my new filter installed, they used 2" from the pump to the filter, and a short section reduced back down to 1 1 /2 after the filter.
Since I will be cutting and gluing a lot anyway, am thinking of going to all 2" for the entire equipment pad. I don't expect a big performance change (the long runs to and from the pool will still be 1 1/2). Mostly it is a consistency/appearance thing.
Still weighing whether to put a heater bypass in, also.
Will this have an impact on the minimal rpm I run my pump at, to keep the current SWCG flow switch activated?
