Hi TFP!
Just moved in and the previous owners left a hot tub for us. Before jumping into any details, we're trying to figure out whether to keep it or scrap it.
Details: I can't figure out the model but it's a 20+ year old Beachcomber powered by a Powersource 2400 motor. We're located around Toronto, Ontario.
Pictures: http://imgur.com/a/pKjXV
Issues:
Sorry for all the detail but wanted to make sure you had all the info available. Thanks in advance for your help!
Issues:
- There are two leaks on the motor side and the opposite side that can be seen in the concrete. There are a few patched cracks in the shell but not sure if the patches are leaking or it's due to ants.
- There are a ton of carpenter ants going in and out of it. Not sure if they are responsible for the leaks but they clearly have nests inside the frame.
- We heard (haven't tested yet) from our neighbour that the heating element in the motor isn't working.
- Can the cedar wrap/frame be removed and replaced? I'd be removing it to exterminate the ants but also to check on the interior and address any other issues.
- My wife is concerned about the energy usage if we keep it. Is the difference between a 20+ year old hot tub and a newer one that significant?
- Are my choices in upgrading the motor limited due to the hot tubs age or is the sky the limit? Any recommendations?
- What are my options for fixing the shell cracks? I've looked for plast-aid but can't seem to find it in Canada.
- Would you keep it?
- If we end up getting rid of it, would like to hear your experiences and advice about how to go about it.
