I'm having some problems with my pool pump motor. Motor specs are: AO Smith, 1.5hp, 230/115VAC, Cat. B129
My motor stopped running a few days ago, and I need some help figuring out what's wrong. When I flip the switch ON, it hums and the shaft will turn slowly - approx 1/2 rev per second. I replaced the run capacitor with a brand new one (25MFD, 370VAC), and I still have the same issues. I checked to make sure the impeller wasn't blocked, and from what I could feel with my fingers, it didn't seem like that is the case. Does anyone know what the issue could possibly be? Should I start disassembling my motor from the pump to see if there's anything stuck?
Thanks in advance for the support.
