Hello!
I'm touching base here to make sure I'm still on the right path with our Baquacil CDX conversion.
I started the conversion on 5/22 and am attaching a photo from 5/23 (gross!) and a photo from today (yay!). Our pump died shortly after we started the process, so I had to improvise with a sump pump recirculating water from one end to the other. The pump was replaced last Saturday and the water was crystal clear 2 days later.
I feel like I should be close to the OCLT, but I'm still losing 6ppm overnight, CC seems to be holding steady at 0.5. I'm using 4-5 gallons of 10% chlorine each day, which is getting spendy! I'm at 55 gallons so far. The process was slowed by the lack of filtration when the pump was out and I've been traveling for work, so I have to rely on someone to add chlorine each night (nothing during the day). Does all of this sound like I'm still on track? Any advice would be greatly appreciated! The water looks so nice, I'm dying to jump in!!
Forgot to mention pH was 7.2 when I started and now it's around 6.8. When would I start to bring that back up?
