Hi all. The hottest week of the summer is descending upon us today (40+++ Celsius in Ontario ) and I really frustrated with this entire pool thing.
I just don’t have money to buy any more chemicals or products or this or that.
There are no pool chemicals supply stores nearby per se- just Walmart, Canadian Tire, Home Hardware. The closest ones are about an hour to hour 1/2 away.
So here’s what I’ve done so far:
•thought the stains were from iron (fit description)
•used 1.5 lbs Ascorbic acid, then did another .5 lb the next day. Stains were lightening - I was encouraged…a few more days & no change.
•shocked it (because I had the chlorine at zero for the Ascorbic Acid) & thought I better add some algaecide (something I have NEVER done except when opening/closing
•kept reading…thought algae was always green …learned it can be black.
-poured the highest recommended amount of algaecide. Stains lightened a bit more but weren’t gone by any means.
so repeated the algaecide again
•been running the pump & filter a couple of days. The water was VERY Cloudy yesterday- not ‘as’ bad today but nothing near normal.
•lots of white foam/bubbles (less today than yesterday) I’m assuming phospates joining onto calcium as I have very hard water
•I’ve backwashed it twice yesterday and twice today.
SO: the water is still cloudy, has foam, stains are still there (and it appears they have discoloured my brand new (and custom order) liner as well
Ran out of stuff for my Taylor kit
so here are the results from the strip test.
Free Chlorine- 0
Total Chlorine 0-0.5
Alkaline
pH
Total Hardness 800+
CYA. 30-50 range
Free Chlorine- 0
Alkaline
pH
Total Hardness 800+
CYA. 30-50 range
