- Sep 29, 2020
- 35
- Plaster
- Pentair Intellichlor IC-40
Our Mastertemp 400 heater was recently serviced. It was purchased about three years ago and put into service about 2.5 years ago, in Central TX. The bypass was broken, blocking water flow. The bypass, o rings, gasket and a new regulator were replaced. The tech noted that he saw corrosion on internal parts that "could be from salt water or alkalinity". See pic below. Our alkalinity is typically 125-150 and Ph runs high during summer so I add about a gallon of muriatic acid per week when it's hot. I also add stabilizer to keep CYA around 50 or higher. Should I be concerned about corrosion of parts? Is there a good way to avoid this?
Also, the SWCG is now warning about water flow when the heater is not running and water is going through the heater. When the heater is running, green light. If I route water away from the heater, directly to the SWCG, green light. I asked the tech about this, his first thought is a dirty filter. I clean the cartridge filters every spring. At typical, low pump, operation filter gauge shows 10psi. At high speed, which we don't really use, the filter gauge shows 30psi. I see water flow in the SWCG when the light is red, so apparently it's low pressure. Does this seem like a filter issue? I would expect red light all the time if so. Maybe not.
