Manually turn on Pool pump
Easy question. I have a Pentair Easy Touch Control System. Is there an easy way to turn on the pool pump
when not in auto mode? I can turn it on/off with my remote controller but want to do it when in front of
the pool system
If you are not in AUTO mode then you are in SERVICE mode or TIME OUT. Press the F FILTER PUMP button to turn the pump on or off when in those two modes.
82683968_473071263352418_1497643315019907072_n-jpg.125555
83107870_594126604481932_3528402847269912576_n-jpg.125556
42,
Yes... Pump the EasyTouch in the Service mode and then push the pump/Filter button. Maybe... :mrgreen:
What kind of pump do you have?? If you have the IntelliFlo pump, you need to use the pump's control panel when the ET is in the Service mode.
