Hello
I have been manually vacuuming my inground pool and I continually get some air intrusion. I have 2 skimmers and 4 returns in the main pool plus 3 returns in the swim- out ( seating area) that I can close off. After about 10 minutes or so it starts getting air in the system and I’ve tried everything to avoid it. I have a new 50’ hose, I close off the far side skimmer and tried closing the main drain but find if I keep it halfway open it helps with better water flow with the air getting in. Still get good vac suction. Any recommendations I could try because I’m rushing to get the vacuuming done the way it is?
I can take video at the pump if it helps
Thanks!
Thanks!
