I bought a house with a pool that uses old Pentair system: an EasyTouch 8 control panel with a SuperFlo 1.5HP single speed pump. I'm not sure how old the pump is, but the panel has an inspection sticker on it with a date of 2013. Everything works well.
There is an extended freeze coming up, and while the Freeze Protection does work, my pool guy suggested that to be on the safe side I should just manually set the pump to run 24/7 while temps are below freezing. He said the way to do that was to put the EasyTouch in service mode, and then turn the pump on using the Filter Pump button on the panel, and leave it.
When I read the manual for the EasyTouch panel, it says "When running the filter pump continuously during a new pool start up, it is recommended to use the “Service” mode." But in the section about the Filter Pump button it says: "The default time before the filter pump will switch off is 12 hours. This button operates in “Auto” or “Service” mode."
Confused, I called Pentair, and the rep seemed to find it impossible that there were no controls on the pump itself, suggesting that they had to have been removed when it was installed. She said that Service Mode should do what I want anyway.
Can anybody with more experience provide some clarity here about how Service Mode works? Does Freeze Protection work in Service mode, as a backup at least? Or, should I just use an Egg Timer in Don't Stop mode?
Thank you!
Thank you!
