So this new pool of ours is MUCH bigger than the last two and it was a bit shocking to see how long it took to get it up to temperature for the kids last weekend. Even more shocking, seeing how much temp was long overnight to the next day - which then means a long run again to get it back to temp. I know as summer sets in and overnight lows aren't as cool this temperature drop will ease but I'm wondering if anyone here has done the "thinking" and come to a conclusion about whether it's more economical to maintain a baseline temp and "turn it up" when planned use is forthcoming or to just let it all cool back down and then bring it all the way back up when use is planned?
I'm ok with it cooling down as I can use the pool as a cold shock swim after my sauna but it takes a LONG time to bring it all the way up. Like 24 hours plus of non stop runtime on the heater and pump. However a cold pool also means any spontaneous use of the pool is a no go since the temp will be way too cold. I don't have the exact stats on how log it takes to achieve each degree warmer but will look into that starting tomorrow as we bring it up to temp for the weekend. In the meantime, any insights from those that have "been there, done that" would be appreciated.
