Hi,
I suspect I may be losing water through the hydrostatic valve in my main drain, so I want to remove the cover so I can check for leaks. The pool is 25-30 years old and has an old flat cover with no screws. I think it is just pressed in, or slip-on, and I need to pry it off with a flathead screwdriver around the edge. It's stuck pretty good and before applying too much pressure I was just looking for confirmation that it's not threaded, or attached any other way than slipped in. Can anyone confirm? Thanks!
