I just replaced my ladder rails and bolts with MG316 versions of the same due to rust buildup that kept occurring at the drill points where the bolts secure the ladder steps. Ladder guy advised that I might have a problem with galvanic corrosion, or high salt. Suggested the use of an anode to prevent rusting the new rails.
My salt has been running a bit high 3800/3600ppm (but not ridiculously high) so I'm discounting that more or less. I also tried testing the water for stray current with a multimeter and got something in the neighborhood of AC 0.012 and 0.0 DC, even with everything running (pool lights, pump., landscape lighting etc) so I'm thinking that is not a concern either. I'm all ears for any other suggestions.
Short of that, I picked up this cheap anode from Princess Auto and thought about cable-tying it to my ladder rail directly. Not sure if it would help but figured it wouldn't hurt? Unless it might. Would love to hear some thoughts about the issue and this possible solution. I am also seeing what looks like the start of some rust on pool light bolts that were replaced several years ago. Nothing crazy but it's starting for sure I think. My Pool Math history is posted here if curious about levels over time. Thanks!
