Lowering TA / pH
Denney
10
Illinois
Fiberglass
I'm in the processing of lowering TA. After pH drops to 7, I'm aerating to bring up to 8 before adding more muriatic acid. Is there a reason why I shouldn't use 20 Mule Team Borax to raise the pH more quickly? I know this raising/lowering is a slow process but sometimes it takes a few days to get pH back up before I can add more MA.
The borax will add alkalinity.
You are using aeration to out gas the CO2 in the water. That allows the pH to rise.
