Low pump pressure
Staci
0
Sep 12, 2016
149
Clover, SC
Taking care of parents pool. The pressure is not like it was last season. They have a filter in the middle of their pool (above ground) I pushed the leaves away to see if the pressure would increase, but it really didn't much, went from 5 to 7 or 8 on the guage (it used to register like 10-12 if I remember correctly) and the feel of the water is nothing like it was last year...it had some serious flow. I can really reach the leaves to vacuum without getting in, and it's to cold for that right now. Could it be that there is debree in there that is keeping the pressure low? Or could there be a problem with the pump?
Possible. What about in front of the pump - the pump basket with the clear lid? Is it always full of water to the lid? Also, it's possible the gauge may be bad. If you turn the system completely off, does the needle go back down to zero?
If it was simply a matter of the filter itself being clogged/dirty, then eh pressure gauge should go up. Since you are seeing the gauge go down, I would explore the fact that there may be a partial clog in the suction line before the pump. Maybe not enough to effect pump basket prime, but enough to slow water down and create a lower pressure.
You might want to check the impeller. My mom's pool would end up with leaf veins getting through the pump basket and then hung up on the impeller. When this happens, pressure would drop on the pump gauge. Cleaning the impeller would clear up the problem with low pressure.
