My new Black&Decker pump arrived and I'm hoping to install it this week.
However, I discovered that the old pump does not have removable unions so I will have to cut it out. I had a couple of issues/questions, though. I figured better to ask before I start cutting.
The inlet pipe is extremely close to the valve and I'm not sure how best to go about it. It also appears that it is glued directly into the valve, but it is hard to tell. Is it actually screwed in and then joined to the pump union with the outer sleeve labeled Suction?
Here of a few pics of the setup. Any advice on the best way to go about this would be appreciated.
