Light switch turns pool pump off and on
Lincoln11
12
Nahant, MA
Can I simply replace this light switch with a timer light switch in order to run the pool pump on a schedule? I have timers set for my outside lights… Can I just use this for the pool pump as well or does the switch have to be 240 V
Is your pool pump 240V or 120V?
Any 240V circuit needs both hot wires switched on or off. There are special "light switch" type switches that are designed to switch 240V circuits.
The Intermatic T104 timer is often used for 240V pump control...
Hi, thank you for your reply. The pool pump is a Hayward 1 hp. I am attaching a picture of the current configuration. The light switch to the right of the plug turns the pool pump off or on. 432201DF-6B49-4586-89D7-82FF005A9D3B.jpegF2E4C993-98BC-4B57-BAB1-6FDD86EDCEC9.jpegA6842F0A-B9A2-4899-BD38-E37E6484DD7F.jpeg69FF0697-DDD7-454E-8EF5-D3ECA277B313.jpeg
Upstairs near the circuit breaker box there is an old Intermatic timer. When I turn it on, it makes a buzzing noise. I haven’t can figure it out how to see if it actually works yet, but I will try that. If it doesn’t, my assumption is I should replace the timer at this location to override the manual switch downstairs, the light switch? Or my original question was can I just change that light switch with a timer light switch that would operate the plug?
No one can say without seeing all the wiring to understand how it was wired. Too many things going on to make assumptions.
Hi. Thank you for your input. Here is the plug for the pool pump, and then the off and on switch to the right of it.
You have a timer, an outlet, and a switch involved.
There are too many wires to figure this out from pictures and wire colors.
Unless you can say if the pump is 120V or 240V and identify each wire where it runs from and to then you should get an electrician to sort this out.
Reactions: SJPoe and proavia
The short answer is 'yes'. You can replace the switch with a timer, but the Timer needs to be able to handle the specific wiring for your pump. 240v setups require you to switch 2 'hot' lines, so the switch part of the timer needs to be able to do that. You also need it to handle the power demand of the pump. 1.5HP is about 10amps out of the gate,
I have the same Hayward Pump (or close enough) and mine is setup for 240V. I replaced the 'switch' and the ugly huge timer box with a single Wifi enabled electronic switch.
I can now setup schedules for the pump via my phone, or manually operate it via the switch, or ask Alexa to turn it on or off etc.
Edit : Just to echo what ajw22 said - if you are in any way unsure, unclear, uncertain about EXACTLY what you are doing when it comes to wiring the switch, pump and outlet up, please PLEASE consult a licensed electrician - Water + Electricity mix only too well...and the results of a bad installation could be catastrophic.
Hi. Okay thank you. I hoped I could just replace the switch with the timer. Identifying wires that are on the switch now and putting them in to timer slots.
Two wires that come from the breakers go to terminal 1 and 3. The two wires that go to the pump go to terminal 2 and 4. Be sure there is a ground that goes all the ay back to the ground buss in the circuit-breaker panel. Also, there should not be a white wire used in a 240V installation. Someone could get hurt thinkin it is a neutral. The breaker in the panel for the pump needs to be a ground-fault circuit breaker. If you're not absolutely sure about your work, please hire a pro. While electricity and water do mix well, they don't do so with your family.
Reactions: SJPoe
