So I have made a crude transit level and I want to make sure it’s a) going to work and b) I’m doing it correctly.
I have a piece of rebar stuck down into the ground round about center. I put my makeshift transit on it so it spins and keeps the same reference point. It has a level on it and I’m using a laser temp gun for my pointer. I’m using a T-square to measure with.
My process is I put the T-square on the 12x12 block where the leg sits, spin the laser to it and level it. Then read where the laser Is pointing on the square.
My low point appears to be at 15” so I’m digging all the blocks down to meet that 15” mark, which also means I’m at 2-3” in some cases.
