My Spectrum Amerlite stopped working on Friday night, both bulbs are dead, and I wanted to update the community on replacement options.
Although I'd like the better colors that an entire LED replacement light would offer, I've got concerns about pulling a new cord and compatibility with my Jandy panel and Zodiac iAquaLink. Bulb replacements retain the original color wheel and controller functionality.
My main question is how important is it to use a "pool-grade" bulb? The bulbs from INYO and other pool suppliers are much more expensive than similar bulbs; what's the difference? The Feit LED replacement looks like a decent candidate too.
Pulled out of my Spectrum Amerlite
GE EYC 71W 12V no glass face
From 1000Bulbs.com
Buy GE ConstantColor Precise 20873 71-watt halogen MR16 EYC flood lamp. Ideal for display lighting. Low prices on low voltage halogen bulbs at 1000Bulbs.com!
www.1000bulbs.com
GE 20873
40-degree beam angle
GU5.3 base
3050K color temperature
glass face
4000-hour life
Buy the Plusrite 3239 MR16 halogen EYC flood light operating at 75 watts. Low prices and fast shipping on halogen open face lights at 1000Bulbs.com!
www.1000bulbs.com
$1.37 each
Searching Feit Electric's web site
3000 hours, 3000K, 38 degrees
track lighting & accent
75 Watts Halogen MR16 - Feit Electric
pool & spa (2700K)
75 Watt Incandescent MR16 - Feit Electric
75 Watt Halogen MR16 - Feit Electric
possible LED replacement 700 lumens, 25,000 hours, landscape lighting, 3000K
700 Lumen 3000K Dimmable LED - Feit Electric
Produce distinctive lighting designs for your living space by choosing this Feit Electric one Equivalent Warm White MR Dimmable LED Light Bulb.
www.homedepot.com
INYOPools
Pentair Spectrum Amerilite (SAM) Light - INYOpools.com has the largest selection of swimming pool and spa replacement parts with over 70,000 parts in stock. Order today and save!
www.inyopools.com
Feit EYC 12V 75W G5.3 $29.99 seems excessive
Florida Sunseeker upgrade kit
Convert your Pentair SAM light to color LED 16 color intellibrite amerlite upgrade conversion kit use existing fixture and save money direct screw in replacement
www.florida-sunseeker.com
$259.99
This one requires removing the innards from the Sam and capping wires.
7 solid colors and 9 color shows selectable by turning on/off
I don't think I'd be able to directly select colors from my Jandy panel and Zodiac iAquaLink controller. The Pentair Sam/Sal only has 9 colors, and unless one of the other lights I can choose matches this retrofit I'd be stuck manually turning on/off to cycle through the modes.
