Just replaced diverter valve as it was leaking and I replaced the spider gasket but still had same issue. It was worth a shot. Approximately 4 months ago I replaced the pump with a Pentair Superflow Variable speed pump as the existing pump failed. Plumbing is mainly 1.5inch PVC but has some very old galvanized 2 inch plumbing. When I replaced the pump I added a Flow Vis H2Flow Controls Flow meter FV- C-15. When the pump programing has the pump running at full RPM, flow rate displayed is 60 PSI. Now the question: The fiberglass tank appears to be leaking from the bottom. As one would expect, I cannot see the leak as the tank is in fixed position and on the base. I have validated that the diverter connections are solid and not leaking but still see water coming from what appears to be the bottom of the tank. It is not leaking at the drain valve. Is it possible that running for a few hours a day at 60PSI has caused the fibrerglass tank to fail? I have no idea how old this equipment is, I purchased the house 5 years ago (built in 1957). The in-ground 40' x 20' concrete pool is old but I have no idea how old all of these items are.
I'm shutting the pool down for the winter (I do run the filter at least 12 hours a day even when closed for the season). If I have to repair /replace the tank I'd prefer to do it in the spring. Is there a relief vale or fitting at the bottom of the tank that could leak? Is this a common issue?
Thanks-
Thanks-
