I have an Artesian Grand Cayman spa that is about three years old. Yesterday I noticed it was leaking from the "DEL AOP Spa Aquanova 2 Ozone/UV-C Disinfecting System." Took that apart and found that the leak was coming from the DEL Ozone Ozonator (little black box in the upper left hand corner of system). Since I didn't have a replacement part -- and the leak was right above my control box where the power comes in -- I simply plugged the supply line to the ozonator, which stopped the leak but effectively disabled the system.
From what I've read on TFP, these ozone/UV-C disinfecting systems don't do much for pools. Does the same go for spas? Wondering if I should repair/replace or just leave disabled. I can get a replacement DEL Ozone Ozonator for $100 (or the entire system for $500), which is pretty cheap, but I'd prefer not to spend $100 + an hour of my time every three years or so on a gimmick that won't have any impact on my enjoyment of the spa.
Thanks in advance for your help!
