Leaking hot tub seal, pipe dope or similar on replacement
hightechburrito
Active member
Sep 1, 2021
26
Lincoln,CA
I saw a puddle under my hot tub today and noticed that seal by the heater that was leaking. I had to partially drain it to undo the coupling to check out the seal and found the gasket underneath had a bit of a cut in it. Already ordered a replacement to fix it, but there was also a bunch of 'goop' in there. Is this pipe dope or something similar? What should I use when I install the replacement gaskets?
For anyone with a MasterSpa, the replacement gasket is X801765. When I ordered the replacement, the website had some o-ring lubricant in the 'frequently bought with', which was FS-8500, and is called o-ring lube. Should I order that too, or use pipe dope from the plumbing area of the hardware store?
Thanks.
Thanks.
“Pipe dope” is generally for threaded pipe connections and “lube” is generally for gaskets.
Reactions: JoeSelf
