All, I've had issues all season, probably longer and never really paid attention to it prior because it just wasn't a big enough problem...well now it is.
2 issues, which may or may not be related -
a) Booster pump leaking at the outlet end
b) air leak somewhere I would assume suction side, but can't seem to locate it.
OK, so the booster pump leak...seems simple enough, cut out PVC, replace PVC...however my question is where to cut in the new piece. Attached is a Pic of the setup , as you can see it steps from a 2in? size to 1in? through a "reducer" however it's all glued together. Not sure why they didn't use a coupling that could be unscrewed, but that's neither here nor there. So would you cut it right after the coupling? Before the reducer and put a coupling so it could be removed in the future? After the reducer and then add the coupling? All sorts of ways to play this, just looking for what makes the most sense.
As for the 2nd issue...I don't believe the leak on the pressure side of the booster pump is the cause for air in the lines and losing suctioning....so I have to assume its from the suction side of the pump. I have 3 valves prior to the pump, skimmer valve (shallow and deep end selectable), main drain and these both lead to the check valve and then the inlet of the pump. I've tried running water over all of the valves and joints/unions and nothing changed. I also ran the water over the drain plug(s) to see if that was the issue and nothing. Water flow at 1750 RPM is so slow that my heater won't even recognize the water flow and gives me a "switch open" status, as soon as I get the RPM up to 3000 or so, heater comes on and stays on, as soon as I kick it down to say 2500 RPM it fails again. As well, when the system is off, I hear a lot of the water drain back out of the plumbing and into the pool (I assume thats where its going). The pump basket never fills completely, usually about an inch or so below the cap, unless I have the RPM at 3000 or so...even then air is still inside the skimmer basket even after purging the filter, so clearly something isn't right, just not sure where to go next on this one.
Any assistance is appreciated.
