Researching this, and from this forum, the two most common places for my gunite pool to leak are the skimmer and pool lights.
Just wondering how to figure this out without paying someone. The leak is small and slow (wherever it is) but I have noticed the pool water level drop at least 2 inches since I turned off my automatic pool filler a couple of weeks ago. The water level in the raised spa has not dropped so I can rule out evaporation.
If the leak is at the pool light, and I pull the light out to replace the "cable seal", the conduit is going to fill with water as soon as I pull the seal out (if it's not already full) so I lose the opportunity to determine if this is the spot where its leaking. But maybe this is still best do-it-yourself method - then I can just wait and see if the water level stops dropping.
If the leak is at the skimmer-to-pool shell connection, it is suggested to let the pool water level drop to below the skimmer and see if it stops leaking further. That's a good test but it also means I can't run the pump/filter for a while (maybe weeks) until the level drops below skimmer. So if there is another faster way to figure this out, I would like to know.
Lastly, it could be leaking at the returns or underground piping. But if I deal with the pool lights and skimmer possibilities myself, at least I'll narrow down the possibilities.
I guess I'll start by replacing the pool light seals (and if you remember me from my other posts, I have an issue with the SAM light not working too, so maybe I just replace it now while I'm there). Don't you just love pool ownership?!
