Sta-Rite intellipro VS 3050,(P6E6VS4H-209L) I replaced shaft seal, seal plate, impeller, and diffuser. I have a leaking when connecting the pump at seal plate to the housing. A new O-ring is used and I have Clamped it tight tapping it as it was being tightened. It seams like the pump goes into the housing so far and the O-ring should be larger in diameter(thickness). I am not sure if the Clamp has to be put on with the hand screw facing in a certain direction or not.
