Hi all! I've used these forums and Pool School in the past for seasonal Intex (in my signature block), but my parents just moved into a house with a lap pool that has been covered and neglected for seven years. Hoping to DIY the resurrection of this pool.
The pump/filter is currently off and the lines are capped. It's a cartridge filter (can get specs on that a bit later, not at the pool right now). I'd like to turn that on ASAP but need to make sure all lines are uncapped etc. first.
This morning I pulled off the cover for the first time and as fully expected, it's very green
1. Volume estimate (~45.5 ft long, ~12 ft wide, ~5 ft deep) is approximately20,000 gallons (maybe closer to 18,000-- I need to get a better depth profile) 16,000 gallons.
2. Vinyl liner.
3. We stirred the pool a bit with the skimmer net-- I'm assuming it's pretty stratified at the moment.
4. After stirring, tested using the reagents I bought last year: FC = 0 (no surprise), CYA = 0 (bit surprised by this?), pH = 7.2 (I assume this will increase once we aerate the pool).
5. I'm nervous about adding CYA until I confirm the CYA = 0 result. Hoping to purchase a CYA test kit at the local pool store (otherwise I'll order one, but would like to do this today)-- my reagents sat all winter in the (unheated) garage; not sure how well the CYA reagent (from TFTestkits) can handle freeze/thaw cycles?
6. I assume the priority should be to add multiple gallons of chlorine to at least start killing what's currently growing-- that's my first plan for today. PoolMath says ~3 gallons will bring us to 10 ppm FC if we had 40 ppm CYA, but I know the chlorine will be consumed nearly immediately by the algae (and if CYA really = 0 then we need to fix that ASAP too).
7. Simultaneously, I'll look into starting up the pump.
Any advice as we embark on this adventure? Thanks!
2. Vinyl liner.
