- Apr 22, 2021
- 117
- Plaster
- Pentair Intellichlor IC-40
I'm planning to install 6 Pentair Laminar Jets on own pump and cartridge filter. I will run separate lines, each with a valve, for each jet from the equipment pad. The runs to each jet location will be flat and range from 50' to 100'. The pipe at the equipment pad is 2" dia and the pipe connecting to the deck housing is 1". At what point in the run should I go from 2" to 1-1/2" and then again from 1-1/2" to 1"? should all lines be 1-1/2" from the equipment pad to just prior to the deck housing or should I use longer 1" piping runs? Should I keep the 1" pipe runs for all lines at about the same length and just vary the 1-1/2" pipe lengths? Should I switch from 2" to 1-1/2" directly at the equipment pad / valve?
Any guidance will be much appreciated.
