I have a Krystal Clear Model 637R Pump hooked up to my Summer Waves Quick Set Pool (8 feet in diameter), and the pump doesn't seem to be working properly. The pump runs for about 15 seconds and then shuts off. I'm then unable to make it run again unless I unplug the pump and open the air release valve. Very small amounts of air come out of the air release valve when I do this.
I have hooked the intake hose to the top pump connection and the outflow hose to the bottom pump connection. The plugs and strainer cap have been removed. The filter is in place. The pump is on a lower surface than the pool. The pool is level. The water level is well above the intake jet nozzle. What gives?
