I've used it with good success on PVC and other plastics. The surface must be clean of dirt and other contaminants (grease, etc.) but it seems to adhere very well and hold its color out here in the hot desert sun.
I like the rustolium X2 paint and primer in 1 at Home Depot. They have every color and finish. I had a few PVC projects that didn't need to be perfect and I sprayed them as is with no prep work. They worked so good I don't bother prepping ones that do need to be perfect. Just make sure its free of dirt / clean and its good to go.
I've recently used it and it worked great. The electrical panel was grey metal with grey PVC conduit and it covered well and the color match was almost perfect. Same as the light switch...it was grey PVC with flex conduit, not sure what the coating is on that stuff but it worked great there also. Good adhesion and almost perfect color match.
