- May 14, 2013
- 157
- Plaster
- CircuPool RJ-60
I've had a Kreepy Krauly for many years and it has served me well. Every year or so I replaced the pleated seal and that was it. Recently, it was just too beat up and ready to be put out to pasture. With such an easy and effortless history, I just purchased the new model of the same device. I have a pebbletec pool and bought the same (new) model with the same pleated seal for multiple surface types. Mine is on a dedicated side vacuum port with a manual regulator to adjust flow between it and the skimmer. Hooked it up, threw it in, balanced the hoses, and now the problem. When it's running, it's fine. I adjusted the vacuum so it's moving at the usual medium clip (like the old one). But when the system turns off at the end of the day and then back on the next day, it just sits there until "nudged" somewhere. Then it goes. It seems like it is sucked down against the pool surface and won't start again until that seal is broken. I've spoken to support several times and tried all sorts of things today. I tried with lower suction, I tried with higher suction, I tried with and without the automatic regulator (my old one did not use the automatic regulator, just tuned with the manual valve). I inspected and flapped the flapper, no debris. I think the problem is that vacuum seal that won't let it restart. Searched all over the web, no hits. Support has no idea but they're sending me a new flapper assembly. Ideas?
Russ
Russ
