I replaced my salt cell in April 2022 after the previous one got cracked due to high pressure because the valves were fitted the wrong way around and allowed to block all flow
Anyway, 2 years 8 months later and the unit is cycling between check cell and waiting. My salt was low at 2000, so I've added 3 bags bringing it up to 3400, then it moved to "lo temp/lo salt", but now it's back to check cell.
Also tried cleaning the cell with an acid/water mix prior to topping up the salt.
Is the cell likely dead and needs replacing after such a short time? These things aren't cheap. Could it be the wall unit or almost certainly the cell itself?
Thanks
Thanks
