Moved from here.
Just wanted to ask for a proven replacement LED for my JandyJLUC10-50 color led. When my fiberglass pool was installed they put a Fusion LED that lasted about 6 years of hardly using it. I replaced it with the Jandy multi color led I listed above. I noticed brown water inside the Jandy today so its toast. I think Jandy maybe bought Fusion? They both used the same docking ring, 12 volt, 10 watt and looked identical.
Is there a time proven multi color light that I can use the same transformer and easily install someone can recommend please?
Thank you
Thank you
