Link to pump https://www.jandy.com/-/media/zodiac/global/downloads/h/h0311700.pdf
Link to Aqualink panel https://www.pioneerfamilypools.ca/wp-content/uploads/2016/05/aqualink_pda.pdf
When I power on the vs pump, it goes to what sounds like full speed (I don't have the plumbing hooked up, just the motor without the wet end attached just for testing purposes so I don't burn up the seal since there is no water flowing through the wet end). I have set the pump so it primes at 600rpm and the default speed for 600rpm, but it just stays at full speed. I have tried the RS485 communication wire with and without the red wire connected since the pump manual says to use all 4 wires, and the Aqualink manual says to only use the black, yellow & green. The voltage between L1 & L2 is 240VAC. The red RS485 wire voltage is 10v.
I have only 3 high voltage wires connected to the pump, 2 hot and one ground. Is this correct for a VS pump, just these 3 wires? The wires are coming from a relay so the pump doesn't get power all the time, just when the timer for the pump comes on and then the green LED on the pump lights up, and a few seconds later the pump comes on at full speed. I am using the wiring from a Jandy single speed Stealth pump so I'm assuming it works with the variable speed?
I bought the ePump used off kijiji so it is possible the speed pump drive electronics are faulty and that's why I can't control the speed, but also maybe I'm wiring it incorrectly. I have gone through the Aqualink PDA menu several times and tried all different settings, but the pump just starts up at full speed and stays there.
What would be the best way to troubleshoot the issue, anyone familiar with the Aqualink RS & the Jandy ePumps? Perhaps my Aqualink doesn't have the required revision, although the handheld does have the ability to program the variable speed pumps.
