I decided to switch from using SpaUp to baking soda. Same stuff, right? But could they be different somehow?
Spa Up says to add 3 Tb for my size hot tub to raise pH. I started with 5 Tb based on my past experience with this tub and it ended up needing 12 Tb! I did two at a time, waiting 30 minutes in-between each before retesting. Took forever.
This is at our vacation rental and there have been 2 groups since I was last here and our service guy comes out after each one, but he's obviously not adding enough.
That's the problem in a rental. NONE of them keep adding and retesting. They check it and then throw some chemicals in and leave.
But who'd have guessed it would take this much? That's why I'm wondering if it was because it's baking soda now.
My Spa Up says soium bicarbonate, but I wondered if there are stabilizers or some inactive ingredients that don't have to be labeled.
I've never before seen it needing this much to raise the pH.
Maybe it wasn't because I switched to baking soda-couldve just been a coincidence?
The pH was well below 6.8 to start . And the alkalinity reading was nonexistent too, although that came up more easily.
