Is there an alternative/cheaper to liquid chlorine yet?
seedlings
58
Saint Joseph, MO
Probably a very short thread but I’ve been using TFP for several years now without any trouble (naturally). Thank you! . A friend has a window cleaning business and I buy chlorine from him, but the price has skyrocket.
Is there any TFP approved alternative to chlorine that is notably cheaper?
You can use granular Cal-Hypo if, and only if, your CH is low. My CH is always in the 50-100 range when I open because of the snow melt. I often use Cal-Hypo until the SWG can take over. The Cal-Hypo may, or may not, be cheaper than liquid. I bought 40 lbs of Cal-Hypo at the end of season clearance last year for $60, but I could never touch it for that price now. It would be more like $275.
Reactions: seedlings
edit: I have an above ground pool - want to make sure a SWG is compatible.
edit again - I learned that it is compatible. Something like $900-1000. I’m paying about $7/gal for 12.5%
If your cell last more than about 2 years, it makes more sense to get the SWCG....This is based on my FC demand in Ohio. MO is further south, so consider it a 2 year break even on the life of the cell. I'd go for it...
Think of it as you are pre-paying for your Chlorine when you purchase a SWCG. Also, you are locking in today's prices for the future because when using a SWCG, the cost of a FC today is the same as it will be in 4 years from now. However, your SWCG has a finite life and being in NH you may get a longer time to consume that finite life because you close your pool vs someone in the south that runs the SWCG 10 months out of 12, assuming all other variables are the same.
this is great, thank you! Might save up for next year. Do you happen to know if every brand base line 20,000 gal SWG are about the same?
Another way to ask is if one brand is ‘better’ than t(e others.
You need to dig into the lb./day output of the cell. Sometimes it is hard to get actual, real world numbers. One 18/20K cell might be very different output from another.
Look at this site - it shows some relative data between brands. Most - not all - put a number in their model name to refer to the volume of pool it is designed for. So then compare the lb/day output and you will see differences between what some would call similar rated cells. So you need to consider brand reputation, warranty, reliability (research the forum), adaptability of the unit to your system.
Very nice resource, thank you. Talked with a buddy tonight. Turns out he has the low value rated Hayward salt and swim $600 unit on his 30’ AG pool, and just replaced his cell after 3 years of doing nothing besides adding salt at startup. Says all he ever does is check pH. (Of course unaware of TFP).
edit: after further review, I don’t understand that chart at all. Many systems with the same output have wildly different value rating. for example that Hayward Salt& Swim vs Circupool edge-15
We've had many previous discussions in threads here about advertised/expected output versus realistic output. We've come to the realization that many of those are a manufacture's projected "best-estimates", typically fabricated under specific/ideal conditions. In general though, generic products tend to fail a bit sooner.
Look at the warrantee differences, and the green circle differences between the two. My guess is the warrantee alone drives the bulk of the value difference.
I have found the discoutsaltpool rating chart to be reasonable accurate in the summarization of the data available from all the manufacturers. I ignore their rating system and look at the output and feature set and they are generally accurate to the manufacturers representation.
To add what others have already said, my opinion is that the big 3 Brands (Pentair, Jandy & Hayward) tend to more conservative in their data whereas smaller independent brands tend to market higher specs but reality is that they fall short of that goal. Back to my earlier statement - So you need to consider brand reputation, warranty, reliability (research the forum), adaptability of the unit to your system.
I think, also, the general thought around here is buy as much as you can afford as it makes the investment more valuable. The difference between a 20k and a 40k causes the cost per FC to go down making it a better deal. I bought one 4 times the size of my pool, and the only reason I didn’t go with the 60 was the delivery time due to back order. I wasn’t waiting any longer. I’m running along at 20% output just rocking along.
Ok. I’m seeing 1.5 to 2x recommendations, and doing lots of reading!
Reactions: HermanTX
